American Patriot 1960
- 41
- 18
So I have a 003 and it is going to be placed in a storm proof reinforced shipping container as a "Generator house". It will have both an intake and exhaust fan to move the hot air from the inside of the container so hopefully the internal temp will be only slightly more than the ambient external temperature.
I was thinking though that it might be nice/bennificial to install some sort of oil cooler. I could put a second fresh air intake fan and put the "radiator" of the oil cooler there.
My reasoning for this is that since the unit is air cooled the only way to suppliment any sort of cooling is by removing some of the heat from the oil.
So my questions are:
1) Would this be beneficial or a waste of time/$?
2) How would you go about doing it? I mean as far as where to tap into the oil system and where to return the oil? I was thinking I could get one of those adapters to use a spin on filter and then put one of the sandwich type adapters on that for the cooler?
I would also install a thermostat bypass so in the winter the cooler would by bypassed or I could just use a couple manual valves to direct the oil to bypass or cooler depending on the season of the year.
Thoughts? Recommendations?
