Hello, I have the genset MEP-803A that runs great. I bought it as a running unit but not making power. I found the FU1 fuse and cap were missing. I did ask about it in another post,,,thanks to all that helped me get those parts together. The generator does make power now to charge the batteries. Unfortunately I did not check the fuse for the voltage regulator and it is blown so I'll have to find one of those now. The gauges are not accurate at all so I'll need to replace the temp unit with something...it shows almost 200 when it's 155 on the upper hose and 167 at the hottest point on the thermostat housing. I did hook up a gauge to the oil line and it is pretty close so that's a win. The fuel shows over full but I only put 5 gallons in it so I may need to run more seafoam in it to possibly get the float skin to clean up...I can get lucky sometimes. So I do see I am missing that update part for pin 7 and 8 on the VR...I'll search that up too to get that on there as well. I want to get this up and going in the next couple weeks...I'll post up what I do and if there's anything you think I should do I'd appreciate any comments. I guess one thing I'd ask is do many of you put a small solar charger on this to keep the batteries topped off?? I am only a few steps away from the back door so I can start it whenever but it may be nice to have them slow charged all the time...I did put AGM batteries in it....600 cca 800 ca so they got a good but of power to kick this over.
Thanks a bunch!
Rich
Thanks a bunch!
Rich
