The larger bulbs had numbers on them, the smaller ones do not. I cannot find a number on themAre you missing the bulbs or do you have one that is burned out for use as a reference. Should be a p/n on base of bulb...I think.
Have you looked at Digi-key? They might have supplied them originally.
Pull the bulb out of the cover with your fingernails.
Thanks I will send them in just a bitThe bulbs should be A327.
On the trailer, there should be a data plate, with the PP number. Take a picture of it, and showm me. Then I will tell you what TM is for that PP.
I looked up the part numbers on those bulbs and they are the larger two bulbs not the small ones.
@Guyfang....................... Sadly, when I tried to upload the TM here, I got a message that the file is too large for the server. .............................
I have 3 of those bulbs from a box I parted out, don't know if they work. Message me your address, you can have them.
Thanks! I was able to open it and find the part number. When I confirm the ordered parts are correct I will finish the thread with them. For anyone in the future@Guyfang
If you can't get the file to cooperate (size reduction), I could PM you an address on one of our servers to drop it on. We have lots of tools to reduce and down sample PDF files. Would be happy to help if you need it. Just let me know...
Tim Mullaney
