Gun Ring M36 / M49
blisters13
78
Beaumont in SoCal
Yep! Thanks for bringing it up!!
I’m considering it, but the additional costs including a pneumatic riveter make it a bit expensive.
If I off-roaded a lot, it would be on there soon.
If I was able to regularly fire an M2 .50 cal., it would already be installed.
Maybe by the end of the year.
WillWagner
2,758
Monrovia, Ca.
Blisters, you shoulda called me, I know where there are cradles and can mounts.
blisters13
78
Beaumont in SoCal
I now needed a replica gun.
Do I want the real thing? Hell yes. IF I could get permission to own a working .50 cal machine gun in
California, they are still about $15,000. Each.
An M60 would have been appropriate for this era vehicle.
I chose an M2 Browning.
The kit I purchased for less than $900 in June 2020.
NOTE: I am NOT advertising for, promoting, nor reviewing this product. I am only stating the fact that
this is what I purchased after several hours of looking at different replicas available. Do not take this
posting as some kind of persuasion to purchase it!
My 17-year-old called this "Legos for adults".
Note the rivets welded inside.
I found that all edges should be smoothed with a grinder flap disc, for better appearance.
The barrel is removable. I have wrapped the barrel at the front and rear of the support tube with
aluminum can shim, while the support tube is being welded to the frame. This method was used
to keep the tubes centered on each other while the welding was being performed.
I purchased a set of NOS handles. While the kit handles are functional and look fine from
a distance, I preferred the correct appearance.
Assembly complete. Approximately 99 steps, approximately 15 hours.
blisters13
78
Beaumont in SoCal
Parkerizing: This took 14 gallons of distilled water and half gallon of solution. It took me 3
hours to get the water from 75 F to 200 F because I used the wrong frickin heating equipment.
A propane or natural gas burner would have been more appropriate. The assembly was bead-
blasted to "white metal" finish before immersion.
This is the compound solution I used.
this is what I purchased after several hours of looking at different products available. Do not take this
The barrel tip still needs the "blaze orange" painted plug.
An earlier post shows an adapter I made to hang the ammo box tray onto the yoke.
This adapter was off by 2 5/8". I had to modify it to get the tray down to the correct level.
blisters13
78
Beaumont in SoCal
I measured the outside dimensions of the various assemblies, then estimated the size
box I would need.
This is what I ended up with. The reason it's not 48" wide, is because I can make the lid from the
standard 48" width sheet steel without a large remnant. The lid had 3/8" lips on three sides.
This is a custom steel storage case I made. It could have been an inch lower
in height. But it holds every part including two .50 cal. ammo cans.
Built 11" H x 16" D x 47" W, 14 gg mild steel; 16 gg would have been fine.
I have a vinyl gun cover coming (which technically means the gun is not "displayed" while driving
down the street).
Parkerizing solution disposal: I could have stored almost 15 gallons of solution for who knows
how long (this stuff is supposed to be able to treat several times), but I don't have the space.
Using the products shown above, I neutralized the solution and will dispose of it at the next city
neighborhood chemical disposal day.
Post-neutralizing. The solids settle a bit.
Pre-neutralizing.
Post-neutralizing.
