MarcusOReallyus
- 816
- Virginia
Same capacity for the front battery and rear. That's the only option. Of course, they can be physically located wherever you want, even under the bed. All it takes is a little fabrication for a mount and lots of copper to connect them.
A bunch of lawnmower batteries could be wired in parallel to get more amps. Might fit under the bed better.
You'll need a couple of upgraded alternators to charge them, of course.
The bad news is, batteries have weight. For lead acid, there's not much difference in the capacity per weight ratings across the different kinds and sizes. Pretty much, X pounds of battery is going to get you Y amp hours of capacity, whether it's lawnmower or truck batteries. TINSTAAFL again.
To break out of that you have to go to a different battery technology, like lithium-ion, and that brings in some charging complications. You would not want want to mix lead-acid and LI on the same charging circuit. But then, you could just convert to LI completely. That would be cool.
Some interesting reading here.
