So now that I have time to get on the computer, there are some answers needed.
1 do you plan to ever put it back on the trailer or will it live in the shed?
2 how do you plan on connecting the nm cable to the inlet?
3 Grounding!! Have to make sure you didnt double bond.
Thanks everyone for the responses- Yes its 4 wire 6/3 with ground
1. Yes, it will pretty much live in the shed for good.
2. I had no idea what he had planned- going with advice here such as LEOK's split bolts sbc4
3. its grounded on the center pin to the main ground in the house, I will drive a ground rod for the portable clamp that came with the MEP.
What LEOK says sounded like what my friend had planned, he said the wall box will become a jct box and simply move the box on the house into the barn.
Scoobyshep- GOOD EYE! yes, I put a T in the underground section of conduct and the yellow #12 hangs a left as when i built the house i stubbed a 3" down the bottom of my breaker box under the foundation for future power to my future 40x60 shop, i ran that yellow wire over to that stubbed off section- all in conduit nothing exposed.
