rtrask
- 250
- 63
- San Luis Valley, Colorado
Unlike a lot of you I have been relatively lucky with my fuel issues, I guess it is my turn now. When I bought my SEE, I had it delivered to my house in the city so that I could work on it. At that time it seemed to start and run just fine on the snake oil that was in the tank ( I assume JP8 ) There was not much fuel in there, (maybe 5 gallons), so I just filled it up with #2 diesel that I bought at the pump. Then I added biocide, and anti gel. Well it took me a lot longer to get the majority of my SEEs issues worked out, and it mostly sat at my house in town for 2 years. There is just not that much that I could do with it there, so I never burned through that initial tank of diesel. I finally arranged transport down to my property in Southern Colorado, and wouldn't you know it, the thing would not run continue to run. I took a look at the filters and the diesel seemed to be sticky. I put a new set of filters in and it ran fine. I ran it for a couple of hours after I got it down to my property and it would always start and run immediately when I hit the starter.
So it sat down at my property for ~ 3 months till I could get back down there, and it would start but die after ~ a minute. In one of the times that it was running I tried to use the little hand pump to keep it going (which was probably a huge mistake). After that it would not start at all. I drained the diesel, put in fresh, put in new filters, got the air out of the filters, but it still does not even fire once.
I have a guess, (injectors / metering pump) but before I tear into that I thought I would ask for advice on the best way to diagnose / correct the issue.
