hello all,
my "new" M1088 has problems getting pressure above 60psi. it takes over an hour to get there. also if i touch the brake petal at all it drops to 40psi.
i found a leaky inversion valve and replaced it, also replaced the roached air dryer assembly with a new haldex unit and replaced the governor / unloader on the compresser.
im going through the troublshooter in the manual but wanted to know if that presure relief valve blowing off at 30 psi is normal. seems to me that if the pressure is low it shouldt do that.
also, i think this truck always had this issue as there was tape over the buzzer to quiet it.
it will build enough pressure to release the parking brakes eventually, but you cant use the foot brakes even once or it will lock up with low pressure..
so what say you about the pressure relief?
chris
chris
