I didn't mean to change this thread into a thread about cooling, but it shouldn't be overlooked when installing a turbo IMO.
For the 6.5 I bought for the M1028 I decided to run a single stat crossover. I've did a lot of research and concluded at the time that the gains from the dual stat crossover where not worth the trouble of fabricating a custom throttle cable bracket. I did buy a high flow water pump from FlowKooler for a v-belt setup.
I'm using the 6.5 in my K1500 as a sort of test rig for now and eventually both engines will be pretty similar in upgrades. Like I mentioned, I run a Duramax fan and dual stat setup (stock on this truck). Oh and I forgot, it does have a high flow water pump (came with this year truck). Today I towed about 11000 lbs for about 16 miles (90% highway at about 52 mph) and engine temperature did not go over 198 F, transmission did not go over 160 F at 64 F ambient. Still no EGT gauge and my boost gauge was removed at the time, but should still be at 7.2 psi max.
My future cooling upgrades:
- Champion aluminum radiator
- B&M 70226 oil cooler for engine oil
- B&M 70266 oil cooler for transmission oil
- Heavy duty fan clutch
- Paradox by Design cooling upgrade kit
- Diamond Eye turbo back exhaust and crossover (besides better flow, it reportedly reduces EGT over stock pipe)
- HX40II turbo (more efficient, hence lowering EGT)
Please note, I'm not saying the above is the way to go. It's what I concluded from hours and hours of Googling and reading forums. My K1500 6.5 will, over time, tell if I concluded right.
