Transmission cooler alternatives
Thumper580
210
Virginia
My transmission cooler developed a leak on one of the external loops. (M998). It lays on top of the radiator. Can these be repaired like a regular radiator? Braze, soldering???
If not, are there alternative transmission coolers out there??? The one I have has four hose attachment points.
Thanks.
frank8003
4,985
Ft. Lauderdale, Florida
Product Details | ENGINE LUBRICATING OIL COOLER
2930-01-168-7911 A heat transfer device specifically designed to remove heat from lubricating oil to lower its temperature. Excludes radiators.20229300045 Engine Cooling System Components, Nonaircraft29350055Engine System Cooling Components, Aircraft Prime Moving
Part Alternates: 12340185, 19111, 2930PL0643713, 5578601, 2930-01-168-7911, 01-168-7911, 2815011687911 , 2930011687911, 011687911
There is lots of them, or one could try to fix one, won't work but could try.
Buy an expensive truck and maintain it $
Thumper580
210
Virginia
Trans cooler kits are available online. Why look for another solution when originals are available? There's no reason to make things more complicated.
An original one is $650.00. Trying to source one that would work and be a better price.
Milcommoguy
2,265
Rosamond, CA
I am going out on a limb here.... If new to the HumV hobby??? Just posting could get you a good deal. Should be able to do better than OEM list pricing or even wack Epay.
Some items do bring a premium, OUCH. $$$ I have a brand new Hood.
Humv Genie , wish this man a T cooler, CAMO
