Thumper580
- 210
- 43
- Virginia
Looking for opinions on my idea to relocate the fuel filter assembly.
Thinking about relocating the fuel filter assembly to the vertical wall section right in front and below the windshield washer tank. Looks like it will have plenty of tire clearance.
No problem to extend the fuel lines......
Regarding the wiring cluster that plugs into the filter assembly.... See any problems with cutting each wire one at a time. Add in a section of wire to get the necessary length, solder it and put on heat shrink to seal it. Continue on with the other wires, doing the same.....
I cant see why it wouldn't work. Much easier access in the new location. Anyone foresee any problems? Thanks.
