24 bolt O rings that fit
Mogman
10,217
Papalote, TX
I purchased some O rings off of one of the auction sites, they were supposed to be for the late 12 and 24 bolt wheels (orange) they listed military part numbers but it does say it "replaces" those numbers, never actually saying they were OEM, no big problem I can send them back.
SO the question is has anyone purchased O rings that actually fit?? and if so from whom?
Please do not embarrass yourself by suggesting I hold them in place with silicone sealer or gorilla snot..... These are just too long to be correct, I actually think a hair short would be better as they tend to move out when compressed..
fpchief
225
South Alabama
Bought one from kascar. Worked good so far.
frank8003
4,987
Ft. Lauderdale, Florida
Is the particular size not in the -P in the TM's?
O-rings are not rocket science although they allow rockets to work.
By now I had thought there would be an o-ring guide in the Steel soldiers.
It should be done and be a sticky but I don't find one.
o-rings are not rocket science and most are not "special" it has a number and dimensions and specifications.
Here, read this for about a week.
frank8003
4,987
a bit more...................
Mogman
10,217
Papalote, TX
Someone suggested I put them in the freezer, it looks like that will work if I can get them bolted together fast enough..............
frank8003
4,987
An o-ring is an O-ring. It is a precise fit. One could make do with many kinds of "fix it back yard" stuff including but not limited to different flavors "lubrication" stuff but why not just get the proper o-ring as per the design.
You screw with the design at your peril.
I have often wondered ........WHY We do not have a fastener and an O-ring database in SS. If I going to do it then I will need much input from many humans in SS
.....Also about every fastener in that truck, what truck? and where to get them.
By Golly, this is NOT rocket science nor is it all a secret.
Curtisje
697
Okinawa, Japan
I have done that with an O ring that was slightly larger than required. I have also cut an O ring to fit and butt the ends together. Since your compressing it anyway I figured it could work. And it did work. Never had a problem with it.
Mogman
10,217
Papalote, TX
I think these folks just used super glue, that seems to be what is provided in most "universal" o ring "kits"
Mogman
10,217
Papalote, TX
I ended up cutting 0.330" out of the Fleabay o ring to make it correct
TOBASH
3,845
Brooklyn, NY
If you cut an "O" ring you need to make a long diagonal cut and then seal with silicone or RTV.
Straight cuts don't bond together as well.
Mogman
10,217
Papalote, TX
This is inconsistant with every procedure I have read, Teflon seals are cut that way but all the o ring kits say cut exactly at 90deg and use a bonding agent.
Curtisje
697
Okinawa, Japan
I cut mine at 90 degrees and butt the ends together with a dab of gasket sealer just to keep it in place while assembling the wheel. In hind sight I should have used rubber cement to fuse the ends together. Since it worked and I have never had a problem I will leave them be until it is time for new tires, which will be soon. They have held air for over 3 years now.
