- 995
- 1,433
- 93
- Wilson County, Texas
With the valve bonnet cover off, when I turn the engine by hand, on the compression stroke, I can here a faint amount of hissing coming from the crank case where the push rods come up.
Is it possible that I do have a compression issue or am I just hearing the pressure build? Does the test gauge have a check valve of some sort that holds the pressure in it?
I may try a compression test again & see if the pressure is dropping to quickly. It didn't drop at all when I did the test.
