Crf450x
- 348
- 63
- Fall Branch, TN
This is in reference to an nhc250 fan clutch. Internals may be the same for the 8.3, I don’t know.
I searched and searched and couldn’t find any information on this. The parts manual diagram looks like Chinese when you haven’t had it apart yet. And the kits are way overpriced. This cost just under $100.
1 each of these o ring sizes....29, 30, 338, 433.
2 small bearings...6206DU
1 large bearing...6017LU
1 friction disc...FC030009/01-3884
I ordered the o rings from fastenal and everything else from eBay. I’m sure there are plenty more sources.
This was my first time ever having one apart and it was pretty simple. Just be sure to keep everything straight as it slides apart. To get the piston out, I used 5 psi and a blow nozzle and just kept it straight. It’s a steel piston in an aluminum housing so keep that in mind. On those o rings I used a conservative amount of silicone grease.
This link may also be helpful https://www.comfortairgr.com/wp-content/uploads/2018/04/fan-clutch.pdf
I took a few pictures but I didn’t get the whole process. But hopefully this will be of some use to someone at some point....
