Inspector 1
- 73
- 28
- Spring Texas
I replaced half shaft boots. I did not want to disassemble half shaft to install new cv joint boots as only the boots were torn. I replaced boots with new old stock. These boots are much thicker than aftermarket boots. I spent two hours trying to use the cone method in trying to install cv joint boot over the hub of the cv joint. No way the boot would stretch over cv hub. I purchased this tool from Dorman. It paid for itself in the 1st 5 minutes. Hooks up to air compressor, expands boot, fits over hub and there you go. A bit expensive at $200.00 but well worth it in saved time.
