I added an ht3b turbo to mine and noticed no difference in power, though I’m sure there was a reduction in egt. I didn’t have a gauge before I put the turbo on. With stock fuel I made about 9 psi and egt would not go over 800. My stock rail pressure was about 150. I swapped the fuel button (#35) for a #17 and it made a huge difference. Egt still won’t go past 800, boost is about 12, and rail pressure is 180. And that’s with no intercooler at all.
For what it’s worth, I saw absolutely 0 difference with the dual fuel line deal, neither subjectively nor objectively. To be honest I don’t even see the logic behind it without more injector flow. But everyone speaks highly of it so I did it.
Im curious what turbo you have? Your egt should be low and you should certainly make more than 1 psi unless it’s some monster turbo or you have a large boost leak.
Edit: I just noticed the air filter. That is waaaay small. I’d pull that off and go for a test drive.
