thread for injector is 3/4 20, odd ball crap/ so the elbow will be drilled out to accept a 3/4 pipe plug for now. to screw the injector into the pipe, a spindle nut from an s10 is 3/4 20 thread, use that welded into the stack. spark plug is simply an 18mm thread, going to used a cut down non fouler and weld into the stack. ned to figure how to lengthen the spark plug wire though. Plans in future will put a sprinkler valve on that outlet, and plumb it into the exhaust. so when the flame thrower system is switched on, some fresh air and turbo boost will entire exhaust, also inject some propane in there, it will ight off with the diesel, spark, propane air=flame. now i am thinking i need to inject all this pretty high up on the stack actually. other wise i may end up with just a flame in the pipe and noting coming out. either way, there gonna be fire.
