sandcobra164
- 288
- 83
- Leesburg, GA
My truck has recently developed a curious condition. It starts fine but sounds like it's only firing on 4 cylinders. After driving about 30 minutes it's fine. Idling for 30 minutes before driving does not cure the issue which in my thoughts would be air sucked in and stuck in the fuel passages in the heads. Let it sit overnight and the process starts again. I'm planning on replacing the fuel lines and fittings from tank to injection pump but I'm curious if a loose injector setting would cause this after years of no issues before I pull the valve covers. Calling out Will Wagner for advice.
