- 1,957
- 417
- 68
- Culver City, CA
I have mulled over the alternatives for replacement transmissions, i.e. 6, 7, 8, 9 or even 10 speed, for my M818, but have run into issues including over length, over width and PTO incompatibility. Some of these problem may be cured, but only after major modification to the drive train. So, I have largely given up on that front.
After some searching, I may have a line on a Spicer 6853-B which is in the same series with the OEM 6453. This series shares many characteristics and parts. The prospect transmission has a different length input shaft, clutch housing and cover/shifting assembly. My plan is to just swap the main shafts and counter shafts from the 6853-B inot my 6453 case retaining the 6453 drive gear.
I am no expert when it comes gear ratios. However, I do see there is difference with the 6853-B having closer on the average ratios, especially at the 3rd to 4th "hole", than the 6453.
Any expert thoughts and opinions are greatly appreciated on this.
6853-B Ratios: 1st...5.08 2nd...3.05 3rd...1.49 4th...1.00 5th... .695 Rev...5.10 | 6453 Ratios 1st...6.07 2nd...3.40 3rd...1.79 4th...1.00 5th... .78 Rev...6.09 |
