- 434
- 206
- 43
- Lynchburg, VA
Hi All,
While in the disengaged (downward) position, the winch control valve on my M35A3 dumps air. If I put it in the engaged (upward) position it stops. Obviously that's not safe, so I removed the valve, disassembled, replaced what could've been a busted oring, and put it back together. Same result. Ok, order a new switch. Same result. I guess it's possible I have 2 bad switches, but......
What am I doing wrong? Air leaks out of the 2 holes on either side of where my thumb is pointing in the picture when the valve is set to 'disengaged'.
Thanks,
SJ/JD
Thanks,
SJ/JD
