- 16,766
- 24,078
- Burgkunstadt, Germany
May be hard to find. Distribution code "D", DOD AND DOD CONTRACTORS ONLY
Figures! Here is my next issue. If course all the bulbs are missing. The TM for the shelter itself has no mention of much anything Internal. I really want to re-use existing fixtures since they are perfect. Trying to source the bulbs.May be hard to find. Distribution code "D", DOD AND DOD CONTRACTORS ONLY
What parts do I want? Light bulbs months ago?Use one Thread for your S-280 questions and progress.
You had three threads started for same item.
If looking for parts, use the Parts Wanted section.
I am going to attempt some fab work for the HMMWV, and I may be able to use to for some fab work on the deuce to so I am gonna go ahead and spring for a plasma cutter. I think you had a great idea and I will be trying it out! Not sure I I even knew I could cut aluminum with one.Do you have access to a plasma cutter? We have had good luck using one to cut aluminum. Oxy/acetelene torches don't seem to work well.
The fluorescent bulbs are 23" and with prongs they are about 23.5"
The cold start bulbs are a very short and the base looks like it would be the same as a normal light bulb
The blackout lights are a push turn...
Looking for all three bulbs so I can fill all the holes. I have seen them all before in shelters and of course gave them no mind.
I am sure they are most likely used in other shelters just have to do more research.
