MTVR
- 743
- 93
- Waco Texas
Behr Premium Plus flat?
Behr Ultra flat?
Behr Marquee flat?
Behr Ultra flat?
Behr Marquee flat?
Of course we will expect photos after your project is complete.We went with the Marquee- after all this work, I'm not about to get cheap with the paint...
I think you may have to invest in a ladderI told her she could "test" the paint, so she attacked it with a 4" roller...View attachment 813902
This is excellent! Thank you very much!Check out this link. 34052 $39/gal
.34052 Flat USMC Forrest Green 1 Gallon Paint WWII to Present – Quarter Ton & Military – Paint Gallons
paintgallons.quartertonparts.com
Yes, it is 383 green, but it is wet, so it looks shiny and darker in that pic...What color is the above photo, 383 green? Couple of technical questions, as I am preparing to do a complete frame off restoration of a '68 M35A2 which is currently in 3 color camo.
1) Was going to try to keep it in a '68 paint scheme but not real fond of the 24087 color. I really like the Marine Corps 34052 color but have heard this cannot be matched in current color codes?
2) What primer has everyone had success with? We are blasting parts down to bare metal. I know many have used the red rusty metal primer but I heard that if there is bare metal with little to no rust, the oil in the primer that is supposed to bond with the rust will have no where to go and thus will react with and bubble up on the paint. Is there an over the counter bare metal primer anyone has had a particular liking of?
Thanks
Hmmm, have many people tried HVLP with the marquee line?Thank you all. I just got off the phone with a Behr paint rep. Trying to avoid oil based primarily because I'm lazy and don't like the mineral spirit cleanup hassles. I'll summarize the info I just received in the event someone is looking to do the same:
- Stated that while the Marquee is intended to be a primer and paint in one, since this is a vehicle application recommends using either Behr 436 multi surface primer or Behr 435 metal primer (preferred If the store you are using stocks 435). I'm not really sure why that matters, vehicle vs. exterior stationary, but he did say their paint has not been developed for vehicle applications.
- Recommended 2 coats of the Behr Marquee as an automotive application for durability and color consistency over bare/previously painted surfaces on same work piece. That means likely 4-6 gallons I'm guessing, but when the final restoration is completed will let you know. Sounds like many have had good results with one application, so we will see how it goes.
- Recommended an AIRLESS sprayer with a tip size of .015 - .021. Their R&D section has tested multiple spray tip sizes and found for this paint the indicated size to be the best for coverage and the nicest finish. I was looking at using an air sprayer, but they advised against it as in their tests the air sprayers made the finish look rough/blotchy and the paint did not level out properly. I suppose that all depends on the size of the tip for that as well.
- Great thing about this paint is you can apply it in temperatures ranging from 40 to 90 degrees.
