mpe803a
Guyfang
24,036
Burgkunstadt, Germany
First, pull the K2 out. Take it apart. They were often filled with water, and it corroded them up. A bit of sand paper and it can be fixed. Wonk cost a bit of money, and the worst that can happen is it don't work. The relay is to be had in the internet.
mchlsprgn
14
jamul cal
ok i'll give it try can the percent of power be fixed? Thanks Mike
Zed254
466
S. Hampton Roads, VA
Use ARMY TM 9-6115-642-24P and search term 'fuel' and you will arrive at Figure 17. Fuel Tank, Pumps and Lines (Sheet 1 of 2). This will show you how the aux. fuel system works.
Guyfang
24,036
Well.......................................... if you want to see how it works, go to the -10 and -24 TM's. The -24P just shows you the parts, not how it functions. Shortly explained, hook up an aux. fuel line to an Aux fuel source, and after the set starts, place the S1 in the Aux Run position.
Zed254
466
I thought the -10 was a little light on details but mchlsprgn definitely should start with the Operator's Manual to understand his machine.
TM 9-6115-642-24 definitely has some good trouble shooting / functional explanations. I believe mchlsprgn has some book work to do!!!
mchlsprgn
14
jamul cal
ordered and paid for the tm got lost in the us mail My po is fames for losing stuff i will try agine my printer is not working up S creek without a paddel
Daybreak
2 Star Admiral
770
Va
Howdy,
Start off in this thread. The 2nd post has quick links to lots of stuff. The 3rd post has the links to the manuals here on Steel Soldiers.
mchlsprgn
14
jamul cal
Howdy,
po gave tm to my son same name defferent po # got some reading to do thanks for the help
