Good morning. New guy here. Just purchased a 94 m998. Seems to be in overall good mechanical condition but I am still learning how works. I have tracked down a power steering leak to my fan clutch. Ive done quite a bit of research on this site and others and still am not clear on exactly how these work. The fan does constantly spin when the engine is running but this seems to be normal from what I’ve read. I did pull the line from the Cadillac valve and apply 100 psi of air pressure. The fan did slide forward slightly but did not rotate. Since I’ve had it the engine temp hasn’t gotten above 180-190 range and it’s cool weather so it might not be warm enough for it to kick on. It’s not leaking a lot of fluid just a few drops after driving for a while. It’s not clear if the leak is coming from the hose fitting or the clutch assembly itself. Just looking for some advice from those of you that have had this problem. I don’t want to pull radiator and dive into this if I don’t need to. Thanks
