Hey all, been working on the air brakes on this truck for some time. when I bought this truck it had 1500 original miles (yes really) the fifth wheel still had factory paint and not a scratch... it would not build brake pressure past 60psi at all, so with help from this forum I was able to determine the cause, 2 frozen check valves behind the tanks due to a corroded air dryer passing moisture.
I replaced the following in July-aug
- Governor
- Air Dryer
- rear brake inversion valve
- 2 check valves
The truck got up and running, and had been fine. Now the system will not Purge air via the dryer or stop building air pressure. An air gauge on the tanks shows 150 when the valve blows, and keeps climbing, but slower. These are both linked to the governor (a new one btw) so I wanted to confirm everything else was working before I blame the governor.
Purge line to dryer
I removed the governor and checked for trash etc, Removed the air purge line from the dryer and blew clean compressed air through it to make sure it was clear, then re-hooked it to the dryer and blew air in again and the purge valve activated on the dryer.
Wet Tank Line
Removed this line from both sides and cleared the line made sure there are no restrictions or trash in the governor..
What say you all? governor?
Chris
- Governor
- Air Dryer
- 2 check valves
Purge line to dryer
Wet Tank Line
Chris
