- 209
- 61
- 28
- Carmel IN
Hi All you Mechanic Guru's. I have a starting problem on my 1986 6.2L. If it were a gas engine I'd think it was a carburetor choke high idle problem. But have no clue on my diesel. It used to start almost immediately even at 0 degrees. Both batteries are fairly new.
I turn the key half way until my glow light goes out. I hold the accelerator down all the way. After a second or so it starts to start then a second later it doesn't fire and i get a big puff of dark smoke. This happens with temps around 55 degrees so I don't think it's a glow plug problem? After I crank it for 5 seconds I keep my foot on the accelerator but turn the key off then back on half way, the glow light goes off almost immediately then I try again. I do this 3 or 4 times then it catches but just seems like a high idle isn't catching?
Once it starts and I drive it it starts up immediately even after it's set for 5 hours.
I am not a mechanic by any stretch of the imagination but would like to try and fix it myself if possible.
Oh it only has 64K miles on it.
What's all your thoughts.
Thanks in advance.
Charlie
Thanks in advance.
Charlie
