Alexandninasdad
- 10
- 3
- Phx AZ. 85008
Unbelievable drama securing a Alternator .. but thats a Rant . Lets start over ..
96 M1083 Purchased in Ogden UT from a company that used to turn these into Overland campers. The truck is a runner but charging is a problem .
The Charge gauge was in the Lower part of yellow and that Alternator tested bad by a Proper Shop. Now i've finally installed what I HOPE is a good alternator after
replacing all LG gauge cables ($$$) to the Alternator and the Battery Box and the >> ?? POLARITY THING << under the spare tire. Does it have a Name ?
Today I took the Batteries to the car parts store for a 12.6v charge and Bench test. All are A-OK. Subsequently the truck starts on the spot. Runs happily etc.
HOWEVER
> Charge Gauge still in the Yellow.
> Output at the Alternator at the YELLOW (front) terminal is 24.5 V Engine Running
> Output at the RED (back) is 12.5 V Engine Running
> Voltage @ Energize Terminal on Regulator Right was 24v
> Voltage Checked at the Batteries all four showed 12.3 V
{??} According to the CE Niehoff Docs i have referenced the Yellow terminal /Front should put out 14V and the Red / Back 28v .... IDK
SO .. I have no wiring diagram to reference in the Manuals I purchased online.. and I need to know what wires go where from the >> Mystery Item under the Spare tire << and what the voltage is supposed to be at each of those 4 Connections.
Additional Details which may not have any bearing at all ===================================================================================================
The INOP Alternator that I removed had the Regulator with LED indicator Lights. # 76761 N1511
The Alternator I installed is : 12420852RB with a 67671-N3030
Voltage output of the INOP alternator that i removed was not noted / Labeled.. i only labled the wires i removed with Red/Yellow.
NO Battery wiring Diagram to be found under the lid of the Battery Box
4 Automotive Batteries are now in the Battery box
HOWEVER
