Blackbear
- 1
- 18
- Houston TX/ London Ky
Need maintenance help off my MEP-803A
After an oil change I started it back up, and electrically other masters with would no longer work to shut gen off, also the emergency e stop
Did not work, only after I moved the dry crank switch to off and waited about 15 mins it shut off on its own,?.
Advice on some kind of short not knowing where, I reset breaker and checked fuses inside panel but the same thing is happening
Can it turn it off.
Thanks.
Can it turn it off.
Thanks.
