This pilot bearing was putting up quite the fight. Tried the grease/bread trick, no go. Tried a 2 jaw puller, no go. Ground down my cheap 3 jaw to puller to fit in there, it bent and broke. Got a 3 lb slide hammer, it just laughed. Started to cut into it but the shell is so thick I'd go bankrupt buying saw blades.
Decided to make a tool from some of the 2 inch steel I got to make a cross member spacer for the nv4500 swap. Cut a strip off it, drill three holes, tapped two of them for long bolts. Used the slide hammer bit to grab the bearing and an impact to drive the bolts on one side at a time. I actually ended up bolting an old flywheel on for the bolts to press on. Finally got the pilot bearing out. Glad to put the drill press to work.
