JD4044M
- 999
- 93
- Okanogan, WA. 98840
Just went out and since the axle is on a jack stand you can't see it flat. Checked the pressure 5 lbs in it and flat again. Filled it back up and sprayed soapy water on parts. First part I did was the fill hose that keeps the tires full of air. The fitting going into the rim is leaking. Looks like where it is screwed into the rim the air is leaking out. Should this connection be wrapped with Teflon or a sealing compound? The tire guy put this on so I am not sure how tight it is??
