spankybear
- 884
- 93
- WA
There are 4 different relays used in the A0 PDP. You have a 4 and 5 pin and 12 or 24 volt coils. I decided to keep it simple and use the 5 pin relays. The 5 pin will work as a 4 pin with no issue. All you need is a 12 volt and 24 volt coil relay. You only need 2 to keep as spares. I chose Bosch brand because they are 1) NOT made in China, 2) seem to be a good quality and 3) the 12 volt coil is gray and the 24 coil is black. I also wanted to get one that had a diode across the coil like the ones that came factory.
Just thought I would put this out there. Hope this helps...
