Winter is coming... Ether start questions!
Asymair95
50
Tucson, AZ
As has been mentioned, a block heater works wonders. I don’t have power out to the parking area, so I went with a grid style intake heater. A diesel fired webasto heater would work too for warming coolant and requires no outside power.
Ronmar
7,498
Port angeles wa
There is no timed metering of the ether. It is metered thru fixed ports/nozzles to deliver X volume per second sprayed, but when the ether sense switch is below 100F(coolant temp), the ether sprays as long as the dash switch is depressed/tank has ether in it.... real simple circuit. CB22 to dash sw, to coolant temp sw, to solenoid, to ground...
The start procedure in the -10 manual(page 2-136) says after you start cranking, cycle the ether switch 3 seconds on, 2 seconds off till the engine starts and runs reliably without it...
glow plugs are usually an IDI thing. DI engines use intake air heaters.
as mentioned the coolant heater is the real ticket, but when you don’t have power... or as mentioned light a fire under it:)
Floridianson
2,503
Interlachen Fl.
Yea I do not know about a fire under it. What we did to some equipment was just heat in coming air. Took news paper rolled it up like your going to swat the kids, light the end and place it close to air intake.
Guyfang
24,145
Burgkunstadt, Germany
We used a "Fire Stick". It was a welding rod, with a small loop in one end. Use a piece of jeans cloth pinched in the loop. Dip in diesel. Pull out air filter, (and some folks do not even do this) and light the cloth on fire. When its burning nicely, crank over the engine and put the fire stick close to the air inlet, or even in the air filter housing. The engine will start RIGHT NOW. Mostly the fire will be sucked out, about the time the engine starts. Starts EVERY time. And no ether.
coachgeo
3,463
North of Cincy OH
our air filter way to far away from engine for this to do much of any good. would take a lot more fire.... but that would use up lot more air inside the intake.... so you end up in a loose loose situation.
Old tractors though use to have a built in system similar... a glow plug and a fuel drip system ignited a fire in the intake up as close to the air pulling into the intake valves the engineers were ok with putting it
Ronmar
7,498
Port angeles wa
Yep, google thermostart...
Floridianson
2,503
Interlachen Fl.
Your just heating the ambient air around the intake. Yes the Deuce and 809 series do the diesel fire thing inside the intake.
BEASTMASTER
142
Burgaw, N.C.
block heater is the way to go if a storm was predicted and it was cold i'd plug the truck in and it was nice and toasty when i had to go out to plow. i had one that u put one end in you're block drain and the other end in you're heater hose, and the thing worked great for 13 yrs in mass. probably still works but don't need it down here.
