how much are we talking about?Yes it's a SPST.
Not any spst will work. In this application it has to be able to handle the current required by the four intake heaters in your 803.
100 AMPERES DC RESISTIVE LOAD |
Hey Kurt do you have another VR? I have one more 803 may as well upgrade it Thanks MikeYes it's a SPST.
I sure do. I have about 10 on hand at the moment.Hey Kurt do you have another VR? I have one more 803 may as well upgrade it Thanks Mike
Yes I doOk great I'll pay pal the money D0 toy still have my mail details?
Hi Kurt I just installed the new vr gen won't start . It was fine before now the relays click dead crank worksYes I do
I must have done something wrong got any ideasHi Kurt I just installed the new vr gen won't start . It was fine before now the relays click dead crank works
II must have done something wrong got any ideas
one thing ,i did not disconnect the battery first could this cause a problem?Installing the VR should have no affect on starting. The two wires you connect to M7 and K15 would not affect the starter motor from operating. Those two connections just pick up 24 volts and ground for the VR operation. I'll noodle on it though.
yes to all of these . the cb1 doesn't appear to be tripped check it tomrrowThings to check...
Make sure the Emergency Off Button is pulled out
Make sure CB1 isn't tripped
Make sure Battleshort is OFF
Does the fuel punp run with S1 in Prime/Run?
Do the panel illumination lamps work?
starter does not engage ,pump runs ,relays click. I'll try the disconnect k15 today and let you knowWhen you say it "won't start" do you mean the starter doesn't engage and turn the engine over or do you mean the starter turns the engine over but it wont fire?
Do you hear the primary fuel pump run with S1 in the Prime/Run position?
Try disconnecting my VR wire that you hooked to K15. Put tape on the lug and then see if the set starts. If it starts then you may have put the wire on the wrong terminal or wrong relay.
is it possible to put k12 thru k19 in the wrong place? I dont know if i sent my last e mail starter does not engage, pump runsWhen you say it "won't start" do you mean the starter doesn't engage and turn the engine over or do you mean the starter turns the engine over but it wont fire?
