Navy dude
- 21
- 18
- Jenkintown, PA
My horn works ok other than the fact that the valve leaks enough to constantly actuate it. It is faint enough that it can be barely heard above the engine noise, just concerned if it fails any more I'll be driving down the road at full blast annoying everyone around. I pulled the valve assembly apart as much as I could, also got the NSN but not available anywhere I looked. I guess I'll just disconnect the air line to the horn, it doesn't seem like enough bleed to deplete a tank when running. The air supply comes in to a plenum that supplies the horn and another item but I can't tell what so that will have to remain but the line to the horn will have to be disconnected. Anyone else seeing an issue like this? Thanks!
