11.00x20 tire chains
travistodd1
11
Camp Verde, Arizona
I have yet to find a deal on a larger set of singles for my truck that I can afford at the time or are close enough for me to pickup. Been thinking of getting some chains for my NDTs. Not a lot out there showing a listing for that size. What have you guys been running? Found these near by and was curious if I could make them work on a 11.00x20?
davidb56
1,238
Bonners Ferry Idaho
thats what Im running on my 11/20's in the rear. Im running spiked chains in the front from: tirechainsrus.com they cost 300$. the 2247's I bought from CL for 100$ a pair. I have a M35a2 and the tires are 43 inches tall, 11 inches wide on the original 20 inch rims.
travistodd1
11
Camp Verde, Arizona
How did the 2247's fit, toght or loose? Thanks for the info!
Karl kostman
893
Fargo ND
If your looking for chains to just get you by until you find the correct ones you can use some shorter pieces of chain and just wrap them around the tire and through the wheel and bolt the chain together. Granted its a pile of short lengths of chain when your done but it will get you by until you find exactly the right ones!
davidb56
1,238
Bonners Ferry Idaho
I have four links that I dont use, so its a good fit. Im not running NDT's Im running Michelins 11x20, so yours may be loose. If they were tight, you can go to a tractor supply outlet, or what ever its called, and buy a few repair links and add to them for a few $$$.
7bdiver
170
33
idaho panhandle
The laclede 2247 chains fit great on the 11x20's I have always liked the cam style. I bought 3 pair for somewhere under 500 bucks home.
Probably won't need them, but better to have them. I put them in plastic milk crates and then those go in the big box in the bed.
Here's a picture. I just tossed one on to check the fit.
I've never bothered to use bunjies on cam style chains. They stay tight just fine.
