- 333
- 741
- 93
- Quincy, FL
While going over the new to me M35A2C I ran across something odd. The truck is a WO/W that has had the correct winch installed. Everything appears to be original parts and the install looks like clean.
While spooling the wire off to take it down for a new thimble I heard a very light dragging sound. Upon further inspection it appears that the PTO driveline is ever so lightly touching the steering box. Being paranoid I expected the worst, like bent frame horns from a previous hit to the passenger side of the truck, but I can find no evidence of this at all. Frame horns are straight as an arrow. I checked the spacing relative to the frame horns side to side and everything looks like it was installed spot on. I also noted that the output yoke on the PTO is so close to the bellhousing that I doubt you could slide a piece of paper between the two.
So, the first question is how much clearance is normal between the driveline and the steering box?
The second question relates to the lead chain and hook. In every picture that I can find of original lead chain/hook assemblies the hooks appears to be oversized in relation to the original 1/2" chain. To me the hooks appear to be a 5/8" version but no matter how many pictures I zoom in on I don't see marking that would confirm or discredit this assumption. Can anyone confirm that the original lead chain hook is indeed a 5/8" version?
Richard
Richard
