Ronmar
- 7,447
- Port angeles wa
No, you have to pump the water and fuel out with the primer. If you look at the stainless ring around the primer bulb, there are instructions printed there.Do the liquids flow out freely? When I open mine, some seems to drain out and then it stops because no air can get in. In order to drain the rest, I have to unscrew the knob a lot, until air can sneak in past the threads. Is that how it's designed to work?
Opening the drain is also a way to check if your flapper bypass check valve above the filter(underside of filter boss) is sealing. If you open the drain and it sucks air back into the drain, that is caused by gravity pulling fuel back down the supply line to the tank thru that leaking flapper valve above the filter...
