Efituned
- 9
- 8
- Midland, Ga
HET and PLS wheels are about the closest relationship to the MTVRThe goal is to get the truck onto a trailer for transport.
Options-
1) try to air up the existing tire on the truck. It's likely an O-ring or CTIS problem and will hold air long enough to get loaded. This is the best option. Least amount of work and highest chance of success.
2) if it wont hold air, load it with the flat tire. The sidewall is already creased so the tire should be considered expendable.
3) swap tires but not wheels. This is more work than it sounds like.
4) worth checking MRAP to MTVR wheel compatibility. I went digging for an answer for you and couldnt find a definitive answer. What I did find is that MTVR wheels are not compatible with the 939series trucks. MRAP wheels are also not compatible with the 939series trucks. Conceivably the MTVR wheels and MRAP wheels are compatible. I couldn't find anything to rule it out, nor could I find anything to confirm it.
Congrats on the truck acquisition!
MATV MRAP wheels.Not exactly sure what wheels that I purchased. I was hoping that they would fit to avoid swapping rims. The problem I run into is my studs being to short. The wheel is about 1/4” thicker than the 7 ton wheel. Everything else looks the same. The pictures below show the new wheels mounted on the 7 ton. Could not stand it. I Just had to try it.
Wide varietyDo 16.00R20 tires+wheels sold on GP generally fit an MTVR? Or are 16.00R20 XZL used for a variety of vehicles?
How are you determining that this is a HET wheel? It fits with no rubbing. The offset is actually less than the original oshkosh mk23 7 ton wheel. It’s definitely not a 7 ton wheel. I plan to try the lug nuts mentioned above by SIMP5782. The Dirty wheel in pic is the original.HET wheels will NOT fit. The offset is wrong and they rub suspension components.
I have some MTVR wheels in NC if needed.
