Dpas1973
- 13
- 18
- New Jersey
Anyone install one of these gps speedometer/tachometer combo gauges?
Which one are you looking at?
I looked into the fancier GPS speedometer/tachometer combo gauges. Of course, they are expensive and assuming you want the gauges to match you need to replace them all.
I picked up a VDO combo from GP (VDO Tachograph Kit 1318-04 AM General 6500627 6680-01-540-3074 57K6126).
It is not at all what I expected. Though it is listed as a HMMWV replacement from AM General, the VDO is larger than the standard HMMWV speedo and is 12v as opposed to 24v. Also it is a tachograph, so it mechanically records certain engine readings. I'm hoping someone takes it off my hands.
Mystery solved.VDO Tachograph Kit 1318-04 AM General 6500627 6680-01-540-3074 57K6126
is for an m915a1, not the HMMWV.
TECHNICAL CHARACTERISTICS
END ITEM IDENTIFICATION(AGAV) M915A1SPECIAL FEATURES(FEAT) 1EA RPM TRANSDUCER AA-1460-AR-R,1EA SPEED TRANSDUCER AA-1460-AR-S,2EA DRIVETIP AA-2035-2,7EA TIEDOWN STRAP MS3367-1-0,1EA INSTALLATION INSTRUCTIONS 6500628,1EA TACHOGRAPH POWER HARNESS RCSK 19524,1EA TACHOGRAPH,VDO 1318-04 713804024PART NAME ASSIGNED BY CONTROLLING AGENCY(CXCY) TACHOGRAPH KIT![]()
If you want add another kit to your collection, let me know. I'd like to sell mine.How many do you want?? I have a couple cases of them 24 volt, Primarily up grade kit for M951A1 . Could work with HumV with clever custom dash layout.
View attachment 820914 Sensors, cables included. Takes the place of speedo and tach locations. 24 volt. Not water proof / submersible.
Be the first to do it, CAMO
Nope. Listed for $25 bucks on the Upay site.If you want add another kit to your collection, let me know. I'd like to sell mine.
