ACUF
- 3
- 1
- Cincinnati, Ohio
Hi Everyone,
Im new to this forum, and new to LMTV, namely a 2001 M1088A1 (Refreshed in 2004). We havent had much of an opportunity to use it as we have been in the process of mounting a knuckle boom. I start the truck fairly regularly, just to let the air system equalize the tire pressures, build operating pressure, and release the air brakes. The last time I started it, (about two weeks ago) it seemed like the batteries were low, and it just barely cranked enough to start, but it did. After letting it run for a little bit, I shut it off, but realized i might have had low batteries and should have let it run a little longer, to refresh the charge etc. Needless to say, when I went to restart it, it just clicked, like it was just a dead battery.
Fast forward to the past week, I have tried numerous things, including jumping from the 12v side for a boost (which I had done a couple times in the past), but no change in its behavior, just a click when starter button is pushed. I did load tests on the batteries, and the two batteries closest to the outside of batt box were low, so i took them out and charged them today, and put them back in after seeing their load testing / voltage where they need to be, to no avail. Just clicking when starter button is pushed..
I have been digging and have seen a number of threads but im still getting different symptoms, ie not even turning over, etc. Tonight I also tried to jump accoss the solinoid on the chassis just behind the starter, but it was dark, although i think it made contact (via a spark) , I didnt hear the starter spin. Anyway, I can keep searching but any suggestions are greatly appreciated! Take care and happy holidays!
Sincerely,
ACUF
Sincerely,
ACUF
