Ronmar
- 7,222
- Port angeles wa
What Geo said, the transfer case and trans use same oil so if trans oil is
o k, somis the trans case.
the oil light in the dash is driven by the 15 PSI oil pressure switch which is located by the oil pressure gauge sender down on the left side of the engine block. if the light isn’t going out, the alternator also isn’t coming online as alt excitation is controlled by that oil pressure light circuit...
