Aftermarket windshield frames
fpchief
225
South Alabama
I got some new inner frames a while back and got around to putting them in the other day. I prepped and primered the hinge (had to re-use old ones) and screwed them in and hung the frames.
Just now tried to lock the frames in and they hang maybe 1/8" too low to pass by the window lock deal on the outer frame. Anyone else had issues with the inner frames not working out? Should I get new hinges? Does not like much to fitting but they definitely do not.
silverstate55
Unemployable
2,124
1,077
UT
Yes, I’ve had the same issues with aftermarket frames; I’ve had to disassemble and reuse the original hinge portion with the new side/lower frames. Otherwise I had the same problems you ran into.
fpchief
225
South Alabama
I am using OEM hinges off old truck. This is really frustrating!!!
37
45
Iran
Hi .
what size of wrench I can use to open frame hinge bolts?
I can't open them using 9 mm and 10 mm wrench. and also bolts got rusty!
Thanks
18operator
1,855
Seville, Ohio
Looks like the lock on the windshield frame sits a bit too low. It might be possible to remove and relocate the lock in a higher locale? Or the tab for the lock (on dashboard) may have to be trimmed?
fpchief
225
South Alabama
Yep and very frustrating. Good idea on trimming the lock
fpchief
225
South Alabama
Where were the frames purchased? I want to avoid buying something that doesn't fit, unless I had just modify the tab lock.
David, I dont remember. It had to be Memphis, Boyce, or C&c. I think C&C. Pretty sure they all get them from same source anyway....China. the problem has to be in hinge....measurements are same. Tried multiple vehicle side hinges and a diff frame too. I just try not to notice it right now. Weather down here is a non issue unlike for you so it makes it a little more tolerable not being able to lock it.
HDN
5,339
Finger Lakes Region, NY
I remember my dad getting a pair of aftermarket windshield panels for his M37. He's only replaced the driver's windshield and he had to modify the new frame a little bit to get it to lock into the windshield frame properly.
How hard would it be to actually fabricate new windshield window frames? I know nothing about automotive glass, but we must be winning a little bit for not having to work with curved windshields :p
gringeltaube
Staff Member
2,641
Montevideo/Uruguay
Not too difficult - if you have the right tools AND the will to get it done right. The Chinese tried, but it seems they didn't have either....
FWIW, I have studied this a bit. For anyone interested, here are the exact dimensions for both profiles, OEM vs. aftermarket, for the WS-frame lower sections.
18operator
1,855
Seville, Ohio
Wow, they didn't even come close to making the aftermarket correctly!
