Here is an updated picture with the function labelled on top of each relay.
S14 is the Frequency Trip Switch. Responsible for sensing when engine RPM > 900 RPM. Causes K16 to open and close.
K12 is the Fault relay. It activates if the sets Fault Monitor detects a fault. Causes set to shut down if it trips.
K15 is the Field Flash relay. When active it causes the sets generator head to be flashed.
K16 is the Crank disconnect relay. This disables the starter once the engine RPM is > 900 RPM. It also enables field flashing.
K19 is the Fuel Level Relay. This trips when the fuel level drops really low causing the set to shut down.
K20 is the Oil Pressure (OP) relay. It closes when there is sufficient oil pressure. If the OP drops too low it trips causing the set to shut down.
K20 is the only "acitve" relay once the set has started and is running.
All the other relays are inactive once the set has started and is running.
I buy a bulk of my parts from DigiKey. Link to relay available at Digikey:
Relay on DigiKey
There are many other parts suppliers that it can be purchased from too.
Used ones are available on ebay for a little less money.
I have plenty of the Voltage Regulators when you decide you'd like to add one to your spares kit.
