I'm new to this forum. Googling led me here.
How is the HMMWV NP242 holding up behind the Cummins converted HMMWVs?
I have a 12 valve Cummins and 47RE that I plan to install in a 2004 Suburban. I want to keep the full time/part time 4 wheel drive capability of the factory Suburban transfer case while having 2WD capability and a manual shifter. I am considering a NP242WJ transfer case from a 4.7L 2002-2003 Jeep Grand Cherokee with an upgraded 6 gear planetary. The NP242WJ comes from the factory with the 1.25" wide chain and 32 spline output shaft. It is my understanding the only difference between a NP242WJ with an upgraded planetary set and an HMMWV 242 is the HMMWV 242 oil cooler and the absence of 2WD with the HMMWV. The NP242WJ has a 2WD mode.
Thanks for the help!
