- 156
- 158
- 43
- Hills of / TN
Question for ya.. What is the widest tires that can be used on factory rims ( on my 85) dually?
also any info on rim spacers would be helpful...
Those may have some flexible sidewalls that you might not care for. A Toyo or BFG 255 85 16 mud tire fits dually wheel very well.Thanks Im wanting to put 35x 9.50 's on the rear
To get the 1", what spacer did you use?I recommend getting your steel dually spacers from this guy, Fred Goeske.
I've got about 1 inch of space between my duals.
I think mine is 3 inch but that info won't help you. I have 16.5 inch wheels. The backspace is different than your 16 inch wheels and I have 37x12.5 tires. You'll have to mount your tires and then figure out the size spacer needed by placing one tire on top of another and then measure the distance in between the wheel mounting surfaces. Add one inch.To get the 1", what spacer did you use?
Things to consider -Question for ya.. What is the widest tires that can be used on factory rims ( on my 85) dually?
