CUCV Mechanic in Southern California??
jplace1011
489
Santa Ana, CA
Hello Everyone,
I live in Southern California, Orange County area, does anyone know a good mechanic who works on Diesel engines/CUCVs?
Thank you for any input, I appreciate it.
jplace1011
489
Santa Ana, CA
What seems to be the problem Sir?
Hi 1love, I have an oil leak. One mechanic has it now, he wants to see if it’s possibly the head gaskets. I’d love to find a great mechanic to do any and all work. It’s been a challenge to find someone.
1love
126
CA
Well I would get your truck back ASAP a head gasket doesnt cause an oil leak! Valve covers, oil pan, and rear main seals do!
jplace1011
489
Santa Ana, CA
1love, thanks for the input. I’m really wondering if it’s the rear main seal. Here’s a link to my oil leak problem:
CUCV Oil/Fuel Leak
1love
126
CA
Watched the video and read the post, it really looks like a slow leak my best suggestion so you can save money and doesn't require any special skill is to hose down the bottom of the engine, tranny and fuel lines let it try and then start the truck and look for leaks. It looks like fuel too me so I would just inspect all the fuel lines, especially around the motor mounts.
MarcusOReallyus
816
Virginia
Check below the IP, too, in the valley, to see if there is a bit of fuel there.
As for a good diesel mechanic, ask at your local NAPA. They often know who's good and who's not. Might look for someone who does truck work.
Whatever you do, be careful about letting them work on the electrical system! It's different from what most people are used to, and this board is full of horror stories of mechanics who decided a perfectly good truck needed to be "fixed", because they didn't understand the system.
Then it's frying time again, you're gonna burn it.
I can smell the links a-melting, at the back.
I can tell by the way you hacked it, buddy,
That it won't be long before it's fryin' time.
(With apologies to Buck Owen.)
jplace1011
489
Santa Ana, CA
It turns out one of the replaced valve covers (passenger side) is slightly leaking. That and the Rear Main Engine Seal is bad. Two mechanics in a row have not fixed the rear main seal problem. It took me and a backyard mechanic to figure it all out.
