When I pulled my LH door I noticed the top hinge was bent...so I straightened it. Big mistake. Apparently some damage occurred to the LH side or door and I had to bend it back to get the door to close. That hinge on the cab side is also rusted frozen and won't adjust. All other attach points are fine so I am still jacking with the LH trying to get the gaps even, flush etc. R&R doors are a pain so I'll live with it for now.I am still not happy with my adjust. The hinges slide sideways (towards driver and passenger side) but not forward and backwards. I used washers as shims to get the rear bottom door edge up. Maybe it is BFH adjusted?
It would be great if someone had a source and a parts number for these bushings.Here was another option back in the day. I'll see if I can find the application of the bushing to share here. It also works great on hood hinges, The doors open and close buttery smooth.
(5) different door hinges? | SteelSoldiers
