What is the largest size oil filter that will fit the spin on conversion? Anyone have instructions on installing, mine came with no documents.....
Thank you! Do you happen to know or can you recommend a proper torque?Usually its the same for all spin on kits. You take the old filter off, clean the mounting position up, install the new gasket (with a little fresh oil), mount the spin on plate, screw in the attaching 'tube' and torque down to specs, then mount whatever filter fits and is available among the list furnished. I've installed one on my MEP-003A and sets on my various Deuces. If you can change a filter without having to watch a You Tube video for pointers, you can handle this!
