- 114
- 208
- 43
- Fredericton, New Brunswick, Canada
I removed, cleaned , adjusted / readjusted 1/2 dozen times. Looks ok but doesn't produce the 2.5 to 3 volts. I have a new one on order. Just wondering if that alone is the reason engine turns but will not start ( no sputtering ects. - similar to gaz engine with no spark)Of course! Pull it out and look at it. Is it ground off? Re install, (after testing of course) and then adjust it again. I dont know if you have done all this again, but sometimes it pays to recheck, readjust.
