TheEquineFencer
- 10
- 8
I have friend that had another guy "working" on his MEPS 806B, he was "trying to wire around a problem" and it appears he blew come CAPS in the governor control board (ESD5551) and the TCM-02 board and God knows what else.
Here's what I'd like to do, or be able to do.
#1 Install another governor control module from another regular governor system that's readily available to just get the generator to run to see if the Generator end is OK. He's looking cheap.
#2 If the generator end is still good, I'd like to install a voltage regulator to regulate the voltage. I have no idea if I can use the original one or not. Aftermarket retro fit would be nice.
#3 If I can get #1 and #2 completed, I'll figure out how to get it set up for shut downs and such using what I have.
He doesn't need all the other "stuff" that came for paralleling and such. He just needs a generator that's as bare bones basic as it gets.
Any help or insight would be great.
